Wanted.Rubber windscreen seal/trim/border/frame.
- My Cars: Audi A4 Quattro (1998)
Wanted, rubber windscreen seal for my Meteor. Or is it called a trim? I refer to the black rubber rectangle that grips the glass, except mine is losing its grip due to a torn corner. No idea what to offer: please discuss. Also on 07580 805727. Yours, PW
A BX fan since buying a 1983 1.6 in 1987 and subsequently a 1.9GTi, three 16valvers and a diesel Meteor. Their deaths have us done parted, save for one 16V sold for restoration, hopefully underway.
Re: Wanted.Rubber windscreen seal/trim/border/frame.
I think I've got a spare one somewhere but I'm not sure and can't check right now - if you don't find one elsewhere, get back to me in ten days or so and I'll be in a position to root around and see if I've got one. It doesn't actually grip the glass - doesn't do anything to hold the screen in at all in fact. It's just a trim. You may find that to change it you'll need to remove ane re-bond the screen.
KevR wrote: It doesn't actually grip the glass - doesn't do anything to hold the screen in at all in fact. It's just a trim. You may find that to change it you'll need to remove ane re-bond the screen.
yep its actually a fillet, it also need to be fitted to the screen before the screen is bonded in place,
im sure you can not salvage one complete, as the edge under the screen is stuck fast in the screen bonding material,
here is part No.'s for saloon and estate
95 619 450
NFP
WINDSCREEN MOULDING
SALOON
95 614 608
NFP
ESTATE
i dont understand why there should be a difference though
Don't know either, but there's different part numbers for mk1 and mk2 screens I think, so maybe estate carries on with the mk1 version as the rear body is basically a mk1 with mk2 front wings. Not sure what the actual difference in the screens is though.
Many Thanks Kevr and Citronut (surely that should be Citronaut), I'll get back in touch in a fortnight as suggested,or otherwise procure one, which I now know is a fillet. The significant event in the fillet's life was the replacement of the glass two years ago. That's probably why the rubber is not embedded in whatever holds the screen in place; it grips through the tightness of the corners. The failing corner is now unattractively safe from wind-lift, stuck down with sticky tape.
when i got a new windscreen for my red valver the windscreen fitters (tower windcreens Blackpool) the guys had no problem sourcing the rubber so get in touch wit a local windscreen fitter to see if the can get something
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
Scrapped:
