ABS Sensor
ABS Sensor
Hi, does anyone know if a pug 405 front bosch sensor is suitable for the BX?
really?
Re: ABS Sensor
Loads of info on here about which peugeot fits and all info on how to do it, know the 406 does but use the citroen plug when you change it. Good luck.
Re: ABS Sensor
On where?really? wrote:Loads of info on here about which peugeot fits and all info on how to do it, know the 406 does but use the citroen plug when you change it. Good luck.
Re: ABS Sensor
It's probably my fault, i'm not using the search function properly, i did look & after reading quite a few posts i gave up, can you post up the link(s) you're referring to "really". Ta
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: ABS Sensor
The 'BX' ABS sensor is made by ATE and is branded FoMoCo!
I've never figured out which Ford this system was fitted to though.
To the best of my knowledge the rest of the Peugeot and Citroen models use a Bosch type square connector and not the round type on the BX.
The BX connector is still purchasable from major electronics suppliers (RS, DigiKey) as far as i know.
