bx steering assistance valve repair
greendale65
Post by greendale65 »
Hi all, Got a bit of play on my steering wheel I'm told its the
steering valve is this a big job to replace I'm told
you can still get the kit for the job.
8) ^^bx> valver
x 138
Re: bx steering assistance valve repair
Post by rutter123 »
Play in the steering can be caused by many things, have you checked the bushes in the bottom wishbones as these can break up or go soft from oil contamination, also check the tie rod ends as these are prone to wear and the same for the bottom ball joints, there is a coupling in the steering rack just up behind the pedals this may be worth checking too., im not sure repairing any sort of valve will rid play in the steering, do u mean the doseur valve or flow valve? Or maybe its the actual pas rack that is worn? Is your tracking set properly? Are your tyres correct pressure? Are your spheres well gassed? Front wheel bearings ok?All the above can contribute towards the feeling of play in the steering.
greendale65
rutter123 wrote:Play in the steering can be caused by many things, have you checked the bushes in the bottom wishbones as these can break up or go soft from oil contamination, also check the tie rod ends as these are prone to wear and the same for the bottom ball joints, there is a coupling in the steering rack just up behind the pedals this may be worth checking too., im not sure repairing any sort of valve will rid play in the steering, do u mean the doseur valve or flow valve? Or maybe its the actual pas rack that is worn? Is your tracking set properly? Are your tyres correct pressure? Are your spheres well gassed? Front wheel bearings ok?All the above can contribute towards the feeling of play in the steering.
Hi, Well don't know last years mot advisory says both track rod end ball
joints has slight play, 2.2.B1F also another garage says it needs
a steering assistance valve replaced. I'm lost at the moment
what to do.
Leobx16v
Post by Leobx16v »
If it's play in the front wheels either rack end or track rod end if it's on the steering wheel the joints on the colum or in the donut
1991 Citroen BX 16v - Red
1991 Citroen BX 16v - Silver
1992 Citroen BX 16v - White
Scrapped:
G650PGX 1989 ph.2 red BX 16v
G-VOT 1989 ph.1 White BX 16v
greendale65
Leobx16v wrote:If it's play in the front wheels either rack end or track rod end if it's on the steering wheel the joints on the colum or in the donut
Thanks Its had a new steering coupling and donut fitted recently
could it be steering assembly valve . if its the steering assembly
is it easy job do I have to remove the steering rack if so take it to citroen
or get rid ( don't really want to do that ) had the car eight years loved it.
greendale65
Its on the steering wheel.
greendale65 wrote: Hi, Well don't know last years mot advisory says both track rod end ball
what to do.
Well you start with these advisory items from the MOT, slight play in a ball joint can show up as quite severe play in the steering system, replace these ball joints first.
greendale65
what to do.
Hi All, Took car to main Citroen dealer today he checked it and said it
was ok, previous non Citroen garage said it needed a steering
assembly valve kit,( there you go upwards and onwards)
^^bx> valver
So you haven't got play in your steering like you first said :?: :?
greendale65
Defender110 wrote:So you haven't got play in your steering like you first said :?: :?
I Thought there was some we will se when goes for mot.
I did go through a bad time with a garage that messed my
car steering up ( cowboy garage ). But I'm getting valver sorted
now .
