Trim parts wanted
deltic
x 51
Trim parts wanted
Post by deltic »
Would anyone have any of the following parts please in black and good condition? Apologies for the lack of correct technical terms...
The circular piece of trim with a draught excluder that the wing mirror lever passes through (my GTi now has a manual instead of an electric mirror)
The circular piece of trim that the door lock buttons pass through
The cap covering the 12V jack in the centre of the rear console (does anyone ever use those three jacks?)
I'll probably be at the X-Rally if anyone is able to help.
Mike E (uk)
Re: Trim parts wanted
Post by Mike E (uk) »
Hi,
I think I have all three of these, will check tomorrow and reply again.
The cap is part of the socket. The mating plug for the socket is available from CPC and Maplin etc.
Mike
deltic
x 51
Post by deltic »
Mike E (uk) wrote:Hi,
Mike
Sounds promising thanks, keep me posted.
Mike E (uk)
Ok, Got the draft excluder & the power socket, just looking for the trim bit.
do these fit around the lock pins on the top of the doors?
deltic
x 51
Post by deltic »
Mike E (uk) wrote:Ok, Got the draft excluder & the power socket, just looking for the trim bit.
Yes, that's right thanks.
