BX 16 gearbox swap
NeilGP
BX 16 gearbox swap
Post by NeilGP »
Can a B2C engines Gearbox be swapped with a 171 engines gearbox?
I want to swap my 1983 BX 16 gearbox with a 1989 BX16 gearbox but before I buy want to make sure that this can fit without any issues.
Neil
A476 RBX
Series 1 BX 16TRS
JayW
x 13
Re: BX 16 gearbox swap
Post by JayW »
Sounds like one's a BE3/1 and the other's the later BE3/5. Just check whether one you're buying has reverse next to 1st like yours does. If it's next to 4th you'll need to swap the gaiter as well.
NeilGP
Post by NeilGP »
Thanks, I beleive that reverse is beside the first but I will triple check.
Neil
Neil
A476 RBX
Series 1 BX 16TRS
