Ignition trouble on 19tzs
chris40
Post by chris40 »
Hi ;)
Does anyone can help me to find what's happening on my tzs.
Haven't got ignition since i've removed my cobra alarm.
Two wires were connected directly and without bypass on the original wires.
A green in the motor bay with scotch and an orange at the bottom of the fuse box.
What are they related on yours ?
Here, attached, two picts.
https://fbcdn-sphotos-h-a.akamaihd.net/ ... cd1718c448
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 9f2ee351e4
Many thanks
Bx 19Tzs 1990
Xantia Hdi Exclusive 1999
Xantia Hdi Sx 1999
Twingo 2 2009
Kaapelimies
x 16
Re: Ignition trouble on 19tzs
Post by Kaapelimies »
Why did you break it? Try to remember where you cut the Cobras wires. Somewhere you have two wires that should be connected together (they were shorted via alarms relay when disarmed). Or you might just have disturbed some connector, maybe from the ignition unit or ignition coil?
chris40
Post by chris40 »
All wires execpt two were just pluged and didn't need to be cut.
Cobra is trying to find me the notice.
And i don't remember to disconnect a wire from the ignition.
I found were this green wire goes.
And a three parts blue connector on the fuse box.
But what is it on the other side of it, i dont know.
Bx 19Tzs 1990
Xantia Hdi Sx 1999
Twingo 2 2009
chris40
Post by chris40 »
https://fbcdn-sphotos-e-a.akamaihd.net/ ... 918e8d6fad
Got you too a green one in the same place ?
It's 12v after contact wire.
Bx 19Tzs 1990
Xantia Hdi Sx 1999
Twingo 2 2009
chris40
Post by chris40 »
Problem solved.
Topic may be closed ;)
Thx.
Bx 19Tzs 1990
Xantia Hdi Sx 1999
Twingo 2 2009
