Hi, I’m after the BX 16V - Intake Filter Air Hose Part # 96065088. Are these available aftermarket or genuine parts?
Thanks, Gordon
BX 16V - Intake Filter Air Hose Part # 96065088 WANTED.
Gordon
Gordon
1948 Light15
1966 ID19
1991 BX 1.9GTi 4x4
1994 Xantia 2.0SX
1948 Light15
1966 ID19
1991 BX 1.9GTi 4x4
1994 Xantia 2.0SX
Toddman
Re: BX 16V - Intake Filter Air Hose Part # 96065088 WANTED.
They are a genuine part, the one from the AFM box to the radiator panel?
I caught a new sealed one on ebay a couple of weeks ago but I am sure you can just get some aftermarket ducting;
I was going to get some just a case of measuring the old hose think it is about 70mm without checking but the early valvers used a ridgid plastic pipe so you might find one of those.
Gordon
Thanks, yes its the connection from the radiator to the AFM. The existing one is wound steel wire overlaid with some cloth which has disintegrated.
Gordon
1948 Light15
1966 ID19
1991 BX 1.9GTi 4x4
1994 Xantia 2.0SX
1948 Light15
1966 ID19
1991 BX 1.9GTi 4x4
1994 Xantia 2.0SX
here is a screen shot from service citroen
https://www.dropbox.com/s/i01rsahr12sr1 ... 4.png?dl=0
and your part/No. goes from the air filter box to the air intake above the rad,
and not to/from the AFM
