I'm looking for 4 matching wheel trims for my TZD Turbo 1990. I'd like the standard ones but I'd also be happy with the trims off a normal BX that look a bit like the alloy rims.
I also have a set of 4 6J alloys off a BX for sale. Good condition but with rubbish tyres still fitted but you wouldn't want to use them. They are not fitted to my car.
Also for sale, a front wing that I think might have been off a 16valve in metallic grey and not bad condition.
John
Wheel trims wanted, Alloys for sale
Crossbow
Re: Wheel trims wanted, Alloys for sale
I have two used ones, and four as new ones but the as new ones I would probably keep as they are impossible to find new.
Sure there are some on ebay at mo.
- x 25
I have a new set as above £100 plus postage (FIRM). PM me if interested.
Crossbow
I think that £100 for a set of wheel trims is a bit expensive. It's perhaps ok for an immaculate car but mine is a slightly scruffy daily driver and doesn't warrant that kind of expenditure on wheel trims. But thanks for responding anyway.
John
John
No Problem John understood.
- Our Trim Guru
May have something (probably early Mk2 R/TR or later TG pattern, maybe TZ-pattern - and probably not A1). If those are conceivably of interest I'll take a look.
- x 25
Says 13" (must be 14" surely!) http://www.ebay.co.uk/itm/X4-Genuine-13 ... 1766204344
Needing a refurb but not a difficult job.
Sounds like a bad case of OCD to amass over 1000 wheel trims!
Crossbow
Hi DLM
If you've got 4 TZ 14 inch trims (in the style of the ones further up this post), even if they are a bit scruffy, I might be interested. I'm currently running on Peugeot 306 trims that suit the car quite well. I'd post a pic if I could work out how.
John
1990 BX TZD Turbo
1973 Dyane 6
John
1990 BX TZD Turbo
1973 Dyane 6
