bx 19 Diesel coolant leak
Dyane425
Post by Dyane425 »
Idling the engine, the coolant suddenly started spurting out of the overflow orifice, all over the alternator. I left it for a few hours, started the engine, and the same thing happened. The level and pressure were checked at mot. The level appeared the same after a lot of fluid loss. Radiator is Valeo, 1 year old. I suspect an air leak. I will replace the cap. Any ideas re: bleeding without having to change coolant? Coolant changed 1 year ago.
Re: bx 19 Diesel coolant leak
Sounds like head gasket to me, hope not, but even though it was OK at MOT time, it could've just let go now. :(
But, on the other hand it could be air as you say... Fingers crossed!
Pongo
Post by Pongo »
Take the rad cap off, start her up and if u see any fizzing and bubbles in the rad water then the head gaskets a gonner.
Nearly always underneath the motor.
x 148
As per the guys posts it sounds like a headgasket, have you tried bleeding the system?
Dyane425
Post by Dyane425 »
Many thanks to all for your advice. The headgasket wad only changed last year by my regular mechanic. Is there a DIY mechanic friendly way to bleed the system, without changing fluid? Do I open the bleedscrews on the radiator and thermostat?
x 148
It's the same as bleeding radiators at home..,
There should be a bleed screw at the near side on end of the radiator, get the car warm, remove the cap (remove slowly) with heater on full open it slowly, it should have a slot for a flat point screwdriver, hopefully you should get plenty of air out, top up with antifreeze.
Mine kinda did what you've described, the thermostat was goosed, try changing that before worrying about the expensive theories already posted. An air leak wouldn't make itself suddenly known a year after a rad change, or have i missed something?
Pongo
Post by Pongo »
How did it look with the rad cap off and the engine running?
Dyane425
Post by Dyane425 »
Many thanks to all for your advice. I'm only just getting to know what's going on under the bonnet.
Post by ken newbold »
Whereabouts are you Dyane425 ?
