T/d bottom hose
65 Peugeot Boxer work van 280k - x 136
T/d bottom hose
Wanted t/d bottom rad hose, hens teeth?
- themildbunch
Re: T/d bottom hose
Yes - think so... I have an old one I was going to use as a template to get more remade but have yet to arrange it... different inner diameters at both ends.
I've seen them repaired by cutting out the damaged / split section and then sleeved with a small copper tube.
I think they often get damaged by rubbing against the droplink to anti roll bar upper attachment.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Re: T/d bottom hose
Has already been repaired but is becoming quite perished, not leaking as yet but wont be long i suspect, i have 1.9n/a bottom hose but no good, think a trawl round the breakers mite be needed to find something that could be adapted. Not been rubbing or fouling on anything just old and tired.
Re: T/d bottom hose
Got one prob solved.
