A weird one: N/S indicators flash at double speed
Mike E (uk)
Post by Mike E (uk) »
The O/S are normal, and the dash indicators is also normal for either side.
All bulbs flash OK.
Only idea I have is the alarm is upsetting the flasher, but then wouldn't the dash indicator also go double speed?
Ideas please.
thanks,
Mike :?
NeilGP
Re: A weird one: N/S indicators flash at double speed
Post by NeilGP »
Indicators going at double speed normally means one of the lamps is out.
Check the earthing of the lamps as high resistance can cause the same as a lamp being out.
You are not using any of the LED lamps are you? These do not suit indicators
Neil
A476 RBX
Series 1 BX 16TRS
