Just acquired a GT, some parts that are damaged or need replacing:
Both B pillar interior lights as mine have disintegrated,
Original handbook,
GT or other interesting wheel trims that would suit it,
Windscreen,
Will add to list as I go through the car some more!
Many thanks
Parts wanted for a Mk1
Pongo
Re: Parts wanted for a Mk1
MK 2 B piller lights will do as they are the same mate.
Nearly always underneath the motor.
milkyjoe069
Brilliant! Thanks for the headsup
You can get a new windscreen from most fitters, if its a bronze tinted one you are out of luck, if its a CLEAR One Paul296 has one in his garage
Also wheel trims are the same as leader/pilot and Mk2 19TRS DTR.
