From a 1990 car with 130k showing, was good and running when removed approx 4yrs ago with no issues, complete with bosch pump and garrett turbo, t'stat housing, intercooler manifold, pretty much ready to drop in, turns over nicely with good compression £125
From same car 5speed manual gearbox, no issues £65
Also available
Hyd pump
Starter motor x2
Flow valve
Pressure reg
Power steering pipe
Bottom mount
Top mount
I prob have all the intercooler and associated pipework somewhere
Located Holbeach near Spalding, South Lincs , could also be collected from Heathrow.
I prob have all the intercooler pipework and the intercooler somewhere
Turbo diesel engine/box for sale XUD7TE
alexrossmartin
Re: Turbo diesel engine/box for sale XUD7TE
Still got all this?
Yes still here
Engine and box now sold.
Still available.
70 amp alternator
Starter motor
Flow valve
Pressure regulator
PAS pipe
Header tank with pipes
LHM reservoir
Intercooler
Top engine mount
Rear engine mount
Hyd pump to flow valve metal pipe
Lower flywheel shield
Still available.
70 amp alternator
Starter motor
Flow valve
Pressure regulator
PAS pipe
LHM reservoir
Intercooler
Top engine mount
Rear engine mount
