Wanted - Battery Clamp
saintjamesy89
1990 Volvo 740 2.3 GLE Estate
2013 Nissan Leaf Acenta 24Kw - x 198
As above, for my GT. Can't have that battery flopping about now.
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Re: Wanted - Battery Clamp
They are the same on all models, tom do you have the 13mm bolt?
8mm BoltTim Leech wrote:They are the same on all models, tom do you have the 13mm bolt?
Pretty sure i got 1 somewhere and the bolt, can post
saintjamesy89
There is a bolt sticking up roughly 45 degrees off of the base area of the battery tray, so I guess I have a bolt! If you do have one rutter123 (sorry, I don't know your name!) then let me know how much, and i'll send you some money. Thanks.
Have you looked on top of the gearbox Tom to see if it's hiding?
saintjamesy89
Ah, no I haven't. Next time i'm over i'll check. Thanks, Tim
Yes 13mm spanner size is an 8mm bolt, bolts are measured by their shank diameter not their head size. If you asked an iron mongers for a 13mm bolt you would need a 20mm spanner.Tim Leech wrote:There all 13mm heads on my lot
Thanks Kevan, of course you are correct, I didn't think of it like that.
