MOT
Phil Brook
MOT
Here's a new one to me. My 1600TGS failed on a slight hydraulic leak but best of all insecure rear light cluster!! The mechanic put in some self tappers but all it needed was the spring clip moving!
Philbrook
Re: MOT
Any visible leaks on the hydraulic system will be an mot failure, ive had this before with a slight leak on the flow valve, a quick nip up on the union solved the prob.
