Front wheel bearing removal
How do i remove the half inner race from the hub stub? I have removed the outer races from the hub carriers but the half inner bearing has not enough room behind it to get a puller onto it, can it be ground off? Any suggestions welcome, also one of the circlips has 2 broken eyes also need to remove this any suggestions here too.
- x 94
- x 117
Re: Front wheel bearing removal
Something like this.......
http://www.ebay.co.uk/itm/Draper-Bearin ... 33a534ec54
Just make sure you get an appropriate size.
rmattila
I used to weld a bit of metal for the tool to grab on. http://www.rmattila.com/images/remontit ... to034.html
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Old bearings removed quite easily, ground off the inner races and a nice big hammer and chisel shifted the outers.
bx petrol auto saloon
If you are still struggling to move the " inner " race from the front hub, you can by sticking the front hub in a vice and use a cold chisel and a lump hammer gently coax them apart. The secret is to remove the front hub from the vice and turn it through 180 degrees every time until it starts to move and continue it will come off eventually
Moving the hub by 180 degrees in the vice is key to getting them starting to come off and a little wd40
Vince
Vince
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
