front strut lubing
tranentbx
front strut lubing
Post by tranentbx »
morning,
could someone point me in the right direction?
I'm looking for the topic about lubing the front struts. had a good look around on here but no luck!
Thanks
Pascal
Re: front strut lubing
2 easy ways;
1) get some LHM in an oil can and pull off one leg of the strut return pipe (either will do) and squirt the LHM down the pipe before replacing and doing some Citrobotics to lube the strut.
2) alternately get some clean LHM in a milk bottle, take off one leg of the strut return pipe (again either will do) clean it and place it in the bottle of LHM whilst in low mode, get an assistant to raise the car while you keep the pipe submerged in the bottle. This will suck up the LHM into the strut to lube it. When you've done both sides do a few Citrobotics after refitting the pipes.
rmattila
Post by rmattila »
Lubricating won't do much good though, if you have a cup of saltwater sitting in the bottom. IIRC, it might be possible to run a thin suction hose to the bottom of the strut through the return hose orifice, if the strut is in high position.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Hi rmattila, how are you these day's? Glad to see you're still able to post up your thoughts & ideas :)
Or place suspension in full low, at the top of the strut top under the bonnet is a rubber bung with a hole in it. I use a small pump style oil can with some tubing on the end and pump some light oil into the top of the strut. Works fine IMHO.
mds141 wrote:Or place suspension in full low, at the top of the strut top under the bonnet is a rubber bung with a hole in it. I use a small pump style oil can with some tubing on the end and pump some light oil into the top of the strut. Works fine IMHO.
Unfortunately this doesn't lube the inside of the strut it just puts oil into the the convoluted rubber strut cover which protects the exterior chrome rod of the exterior of the hydraulic ram which just gets scraped off by the scraper seal.
rmattila
Post by rmattila »
MULLEY wrote:Hi rmattila, how are you these day's? Glad to see you're still able to post up your thoughts & ideas :)
Still alive and on my own lungs against all odds. Completely bedridden for a year now and lost all consonants which makes speaking most languages impossible (Hawaiian could be an exception). Given away four of my five BX's and bought a Ford Transit with a wheelchair lift. Could definitely benefit from a hydropneumatic rear suspension: my head feels like a bowling ball with most of the neck muscles gone, and my wife has hard time driving carefully enough to avoid breaking my neck.
Sorry for the off-topic.
At least you've still got your sense of humour. :-)
Never mind about the post hi-jack ;) Glad you're still able to get onto the forum, & sounds at least like you can get out & about a little bit. I can't even begin to imagine what it must be like for you. You were going to do some research into your condition, how have you gotten on?
rmattila
Post by rmattila »
[off-topic]We decided to set up a dedicated non-profit organization for promoting our own research and funding that of others. Seems there is interest in the subject among the public.[/off-topic]
Wow, amazing effort, only a small portion is in English, do you accept donations?
andycadabra
Post by andycadabra »
I followed the advice given on the Australian BX forum, which mentioned sucking LHM into the struts by the return pipe, but also, with the suspension on high, pulling down the plasticky rubber upper strut covers, after pinching the tops ( these protrude through two 15mm holes in the top of the Strut) in the engine compartment.
You can then reach about 3 or 4 inches of the inner Strut to smear silicone grease on. This alone has made a noticeable difference - no more of the once-a-second creak when rising to high position.
I also noticed there was a hole where the strut cover is supposed to protrude, on both sides. I think the plastic must have broken, and since you can feel the inner strut through this hole, it may have contributed to letting dirt get in, or the strut drying out, so I blocked it up with silicone grease. It occurs to me that the hole might be there to allow ventilation while the struts are moving, so any opinions would be welcome.
I'll get around to doing the LHM trick in the near future
1992 BX 17TZD 130k
1987 BX 16TRS SORN
