Hello all, My screen wash not working is it the stalk as it is silent
when applied or the little pump on the bottle fuse maybe,
car going for mot couple weeks, ant ideas.
Black valver.
front screen wash not working
- greendale65
- x 20
Re: front screen wash not working
Remover the washer bottle and check the washer pump. The rubber tube that exits through the wiper spindle often gets blocked and could have burnt out the pump or caused a fuse to blow.
Swap the motor from the rear wash bottle, somtimes the connectors can corrode, see if you got volts at the connector, stalks do fail but most likely the motor.
- greendale65
- x 20
Ok all, will sort this week thanks.mds141 wrote:Remover the washer bottle and check the washer pump. The rubber tube that exits through the wiper spindle often gets blocked and could have burnt out the pump or caused a fuse to blow.
