BX Turbo Diesel radiators and hoses - available soon!
KevR
Post by KevR »
As some may remember, a while back I sent a set of BX TD hoses and radiator header tanks off to the mystical East (China, not Dagenham...) to the same firm who make the all-alloy rads and silicon hoses for GTis you see on Ebay.
Just had some pics from them of the first protoypes, so here they are:
The rad is 50mm double core, same as the GTi version. Only thing I can see wrong at first glance is the overflow pipe fitting (to header tank) appears to be missing. I've pointed that out to them. Planning to get a rad and set of hoses sent to me to see if everything fits, then all being well they should be available direct from the makers - prices tba.
Hoses available in black, blue or red.
Re: BX Turbo Diesel radiators and hoses - available soon!
Good work! Silicone hoses are a great idea.
Cool!
My TZD is looking forward to a new set :)
=D> =D> =D> ^^ ^^ ^^bx> Well done that man, top of the class.
Thread Bear
Post by Thread Bear »
Permission to say, 'ooo, ooo, Mr Peevley'.
Mmm, coloured octopi.
x 138
Post by rutter123 »
My t/d will be needing one soon, the white crusty deposits on the bottom corner are a sure sign its on its way out. Will these be priced in line with the gti rads on offer?
KevR
Post by KevR »
Should be, yes. Waiting for confirmation but AFAIK they should be about the same.
TizzyD
x 10
Post by TizzyD »
I'd be very interested in a set of hoses and a new rad or two just to have a spare just in case :wink: :)
KevR
Post by KevR »
As soon as I've trial-fitted a rad and hoses, then I'll come back and we can put together a group order.
TizzyD
x 10
Post by TizzyD »
Excellent, look forward to see how this turns out :D
KevR
Post by KevR »
Quick update - two rads and sets of hoses have turned up chez moi - I'll try and fit one set to the grey one this week if I get a minute, to make sure there are no immediate problems with fit etc.
themildbunch
Post by themildbunch »
Fantastic - i'd been thinking about doing this for a while but hadn't gotten around to it.... now I can dump my old bottom hose I'd been keeping as a template!
Heat shielded. braided coolant hoses next?
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
KevR
Post by KevR »
I can ask!
KevR wrote:
I can ask!
That's overkill isn't it when silicon hoses will be impervious to high temperature heat anyway?
I remember when we got silicon cable for the soldering irons, you could wrap the cable around the hot parts without it sustaining any damage. 8)
KevR
Post by KevR »
Right, update time....
I've dry-fitted the rad and hoses. Mostly good news - they've made one of the lower mounting spigots too big, which is easy enough to modify, but I'll let them know about that and they should sort it for production versions. Otherwise the rad itself seems to fit pretty well. Naturally once fitted it's hard to show it in pics but here goes:
