Power steering leek!!!!
Alastair
1989 Bx estate with power.....I got fluid leaking from around the spindle..... As in where the column enters the steering rack.....firstly I believe there is a repair section available but then I discover it's nearly £140 plus vat! So what's the answer? A second hand rack? Any thoughts? Any help?
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
Xantia 1.8 16v
- x 94
Re: Power steering leek!!!!
The leak will be from the pinion valve seal by the sounds of things. It unbolts from the rack and is replaceable (that's likely the bit you've been quoted £140 for.) It is possible to overhaul them too. I've got a recon spare somewhere in the garage, and a used rack that I could be persuaded to part with.
Alastair
Tell me more Kitch and your location?
Xantia 1.8 16v
Xantia 1.8 16v
Fareham as per his avatar lol! Kitch if your coming to the Chevrons I can get it ALOT nearer to Stoke (Burton On Trent)
Alastair
Keep me posted please
Xantia 1.8 16v
Xantia 1.8 16v
