Aircon Component Diagrams - Chapter 12
BXTASY
My Cars: 1988 BX 1.9 GTI
Post by BXTASY »
1988 1.9 GTI with aircon - I recently downloaded parts of the BX Service Manual, and happy to find Chapter 12 on air conditioning - two pages of component locations on the car, and one circuit diagram. Can’t find the names of some of the numbered components - some are not in the wiring diagrams’ “Key to Diagram 6” for cars from ’87.
What are #
60 (probably aircon control module?)
95 (near fuse box, not shown on wiring diagram)
270 (heater temp control knob, shown as a switch but isn’t it a potentiometer?)
620 and 621 (recirculation flap motors?)
345 (resistor from 762 relay)
837 (potentiometer?)
Relays: (for what?)
733
742 (compressor relay?)
772 (r.h. engine fan relay?)
773 (switch after the l.h. engine fan relay)
I’ve deciphered most of the component symbols, but where can I find an overall Key to these? Not found in Haynes, Revue Technique, or any other documentation I’ve come across.
x 116
Re: Aircon Component Diagrams - Chapter 12
BXTASY wrote:1988 1.9 GTI with aircon - I recently downloaded parts of the BX Service Manual, and happy to find Chapter 12 on air conditioning - two pages of component locations on the car, and one circuit diagram. Can’t find the names of some of the numbered components - some are not in the wiring diagrams’ “Key to Diagram 6” for cars from ’87.
What are #
Aircon control unit/relay
Main junction and fuse box
Microswitch on heater knob enabling maximum vent fans speed via relay 745
Yes
Fast idle solenoid
Evaporator temp sensor
Relays: (for what?)
733
Cooling fan relay used when a/c is on
Yes plus the fast idle valve
Think its actually the RH fan relay
Relay for high speed twin cooling fan mode
