Seatbelt stalk needed asap.
x 138
Post by rutter123 »
Needed as a matter of urgency seatbelt stalk front seat passenger side, for the bx tzd, my one is sticking and not releasing the belt at times, required asap mot booked for coming saturday.
Re: Seatbelt stalk needed asap.
Pop to barry at Bourne, he has plenty (you have a PM aswell)
Tinkley
Post by Tinkley »
You may need the ENTIRE seatbelt as not all the clip in ends are interchangeable.....as I found out a few years ago. You might be lucky, but without seeing and matching I would get the whole thing, the reel inside the B pillar and the Clip in end.
Anything up to 1989 tends to be the early type, anything after tends to be the later type. If you've got the bottom with 'Press' embossed on it, you've got the later one (with the square tab on the clip).
Early one is more orangey on the button, which is slimmer, and no writing. The clip end is more like an anchor.
