More aimed towatds reliability and fuel consumption as this is going to be my daily driver, i intend to convert to continually troublesome gti to diesel, i have a complete XUD7TE engine and box with 80k's on it and has been fettled to produce 15/20% more power than standard so not far off the gti figures anyway. Not being an electrical wizard my concern is can i utilise the original gti loom? Certain bits of the original loom will become redundant such as fuel pump relay and injector relays and ecu etc etc, is this a viable conversion or is it more complex than that?
Things to consider, rev counter,abs,glow plug timer, would also want to keep the oil pressure/temp gauges by fitting senders and such like. I have 99% of the bits to do this inc intercooler, header tank and all ancillaries, but no rad or pipes at mo.
Your thoughts.
Converting gti to diesel
65 Peugeot Boxer work van 280k - x 136
