Is this possible? or do I have to try some other tricks to get the catch to rise over. I'v had two BX door catches break the internal pin before but the problem was not that the door was shut, you had to have a rope to hold it closed, until catch replaced. Not sure if this part is still available and almost certain you can't repair the friction welded pin (which beaks off inside), so any spare o/s front door catch would be welcome. I think this car has been broken into before as there is passenger side damage around the door that side however the catch there works OK. It's not too bad to change if you have the door open and access...
Do any other Citroen/Pug models use the same door catch? like 305/309/405?
