Heater fan blower motor
Alastair
Post by Alastair »
Has anyone ever changed a heater fan blower motor? What's the access like and from where?
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
x 16
Re: Heater fan blower motor
Access from under the bonnet, remove wiper and plastic scuttle panel, then remove several M6 fasteners holding the motor assembly to the car. You may be able to just unclip the motor housing in situ to change the motor, but I've never tried this. Make sure the motor is definitely at fault before condemning it though! There is information in the Tech FAQ which may be useful...
x 26
mat_fenwick wrote: Make sure the motor is definitely at fault before condemning it though! There is information in the Tech FAQ which may be useful...
As this /\, It is normally the motor earth that goes on the circuit board behind the control switch.
