Wanted
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 99
Wanted
Post by rutter123 »
Rev counter pick up sensor 3 pole for 1990 t/d (the one at the back of the gearbox) or a point in the right direction of a supplier or even a part number. Is it the same as fitted to a petrol engine?
Richb
Re: Wanted
Post by Richb »
If you send me a pm with a vin no i can look on the citroen system for a part no if you want.
2001 Peugeot 206 2.0 Hdi
1999 Peugeot Expert Van
1993 Citroen BX 1.9TXD
1992 Citroen BX 1.9TXD
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
Re: Wanted
Post by ken newbold »
I know there's one in the garage, I'll need to test it, if it's ok it's yours for the postage. £
x 99
Re: Wanted
Post by rutter123 »
Hi Ken, that would be good, mine works for a few mins then stops, its been doing this for a few months now im hoping it is the pick up not the tacho head let me know when you find it and I will pm you post details, thanks.
Re: Wanted
Ok, been in garage and found it, tests ok, but before we go any further, a couple of things to try.
1 Make sure your connections are good in the brown plug.
2 Make sure your exixting sensor is pushed fully home in it's mounting. From memory, I think they will touch the flywheel, so just edge it back a little. Had this fault myself once and re-seating it cured the problem.
If you've already done that, send me your address and I'll post this on.
