Wanted parts for 1.9txd
Richb
Post by Richb »
Decided this is possibly best way to look for parts. See whos got what and may be willing to sell.
Advice on parts that are still available is welcome!
Parts i need so far
1) handbrake cable/s *
2) 2 x rear arm rebuild kits. *
3) glovebox (or are they all broken??) *
4) citroen bx 1.9txd badges. None on the car.
5) a wheel trim or set of. I havent a pic handy but little black ones that just go around the nuts are fitted. Will take a pic in the light.
6) wheelbrace and jack (genuine ones)
7) handbook if anyone has one kicking around for one
8 ) the trim around the steering column
9) heater panel. Think i need the lot as the knob turns without resistance.
10) rh rear txd door trim panel (it is recoverable)
11) a rear bumper with chrome trim
1-3 i know can be had new, but if anyone has any surplus ones!
I'm not desperate for the bits. Just trying to get stuff together. But if anyone has any spare bits or is breaking one let me know
2001 Peugeot 206 2.0 Hdi
1999 Peugeot Expert Van
1993 Citroen BX 1.9TXD
1992 Citroen BX 1.9TXD
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
sdelasal
Re: Wanted parts for 1.9txd
Post by sdelasal »
I have item 3 in black going spare. I think I have one of item 2 and maybe one or two of item 1. I need to check the last two items though but am now away with work until friday. Steve
Post by ken newbold »
I think Thurdsday is the big E day for my mates scrappers, I'm going with him so will see if I can find any of what you want.
Richb
Post by Richb »
Thanks ken and steve.
I need a headlining screw cover too. Will take pics at lunch.
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
kernowtim
My Cars: BX 19 estate
1999 ford focus 1.8TD
Post by kernowtim »
there was a red txd estate at chevronics for spares/breaking, you may be able to get parts there!!!!!
Richb
Post by Richb »
kernowtim wrote:there was a red txd estate at chevronics for spares/breaking, you may be able to get parts there!!!!!
Will give them a call. Need some bits they do in the future so will be worth a call.
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 99
Post by rutter123 »
I have a grey glovebox with good hinges if any good. Rear arm bearing kits are readily available on ebay prices vary buy the best you can afford.
Richb
Post by Richb »
My dash is the black one. At least its a dark gray one. I need to remember how to get pics on forums!
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
My Cars: LOTS!
x 122
If it's a txd its black inside.
Tinkley
x 6
Post by Tinkley »
AFAIK, handbrake cables are still available, the PTFE coated (greyish) on the inner cable are the ones to go for, they don't freeze up with water in the winter so much... :wink:
Rear arm bearing kits are also available, same as Xantia, try Eurocarcare - googly them. Their kits are Italian manufacture and seem reasonable quality, though the SKF ones are still around too. I've fitted them on a couple of cars now, but not enough miles to know if they are good or bad. Tolerances on fitting seem good though ie taper housing seating etc etc.
Other parts are more specific, though on manuals the old brown Haynes (pre '88) has more info than the later blue all model version (but of course, the later one covers some later additions), and you'll need the diesel specific engine book too.
Got you a rear bumper, steering shroud, jack and wheel brace.
Richb
Post by Richb »
Thanks ken.
If you send me a pm i will sort out with you.
More good info on here:) although im getting grief for not starting the mrs' mini.....
Wonder if steve found a glovebox lid?
Ive got a few bits spare too now. A bloke saw the car and brought a few little bits. 1.9 16v steering wheel and a spare remoto sensor. Mine doesnt have that and i like the single spoke wheel so they are spare.
1980 Triumph TR8
1972 Triumph Stag
1967 Triumph GT6
I'm sure we can rustle up a glovebox lid if needs be
