Clutch query GTI 8V
x 138
Clutch query GTI 8V
Post by rutter123 »
Im currently searching for a replacement clutch kit for the gti 8v, from what I can see there are 2 different diameter clutches the first being 215mm and the second being 200mm . My engine code is D6A xu9j2 type which I believe was only fitted to jetronic models from 06/89 to 09/90, it has the ball socket and pin arrangement on the clutch arm, can anyone clarify which one I need I have not yet removed the old unit so cannot measure it. The VIN no is VF7XBEG0007EG9443.
