Diesel Pump Diaphram needed
Post by kiwi »
Does anyone know of a source of this part for my TZD Turbo diesels pump.
Details we have is its a Lucas Cav Type 058
Part number is DPC-R884-3B454D
Sere no. 610669mhf
Hunting high and low in New Zealand without much luck.
1990 BX19 TZS Auto 06/11/1989
Re: Diesel Pump Diaphram needed
Sounds like you have the same pump as mine and I'm after a boost diaphragm which is possibly what you're looking for, so when I locate a source I'll let you know...
Although I need to check I actually need one I do want to have one spare at the very least!
x 138
Post by rutter123 »
Do you have a local diesel specialist? As the diaphragm is prob common to more than one pump.
jamescarruthers
x 37
Post by jamescarruthers »
I had one go recently on the XM. I has a similar old Lucas Pump (062). I got parts from Tony at Colchester Fuel Injection. My part number probably wont be the same but they were very helpful so may be able to help you too.
http://www.club-xm.co.uk/forum/viewtopic.php?f=5&t=7716
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
themildbunch
Post by themildbunch »
You can get these as just the rubber part from a UK eBay seller, who's really helpful - I've posted the link before - can't remember it offhand...
The other part that's often sold is the whole unit with the housing that screws in and includes the diaphragm - I bought one a few years ago and it's a Delphi part around £100GBP...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
KevR
Post by KevR »
http://www.diydieselshop.com/ - the best source for anything for older diesels, and also very generous with advice/diagnostic experience. He'll post worldwide.
How do I find out what model pump I have: I can't see any numbers on it.
I know its Lucas. Image
KevR
Post by KevR »
There almost certainly are numbers on it, but they're on a rivetted blue/silver plate that's almost impossible to see. On the main body of the pump (round bit) probably can only be seen from underneath, with a mirror on a stick... Usually covered in muck which doesn't help. If you're just after the BCV diaphragm though, I'm pretty sure they're standard for all those Lucas DP pumps. They are an utter bastard to change in situ, by the way - don't try and fiddle at it from above - removing the radiator and intake piping makes it a LOT easier.
KevR
Post by KevR »
BTW, I'm intrigued. What's with the modified crank breather layout? And the wossname cable tied to the crank breather hose...? Looks like a mini relay but not fully connected?
The breather was repositioned when we fitted the induction kit and temp sensor. The cone filter and so on worked well, but was too noisy so I've since changed it all back (putting a K&N in the standard box. Much better). The cable is from a switch in the cabin for a fan override. This is WIP as it's not all wired up yet. Should be done this summer along with getting a resistor sorted for the temp dial which although neatly positioned to the right of the instruments on the dash, reads 100 when it should be reading 82 degrees lol.
KevR
Post by KevR »
Ah, I see. Mainly asked as I'm about to re-plumb my crankcase breather so it goes via an oil catch tank rather than straight to the filter box. Might vent it to air or a separate filter, don't know yet. That way should avoid the problems associated with high mileage TDs breathing a lot of oil back into the intercooler and hence clogging the BCV and pipe.
I'd recommend ditching those pre-insulated blue crimps on the relay btw, and using some proper crimps....
