So here we have a set of genuine factory/accessory BX alloy wheels. Design type : type 4. (See the full list of wheels available for the BX here at http://www.bxclub.co.uk/forum/viewtopic.php?t=19283)
Complete with a set of good quality 165/70 R14 tyres fitted, as follows:
2 x Conti EcoContact3 One at 6mm, the other between 4mm & 6mm thread depth
2 x Michilin EnergySaver each with 8mm thread depth
I'm looking for offers....? PM me.
Also, one correct spare steel wheel (intended for use with the wheel bolts you'll be using if you run on alloy wheels). Comes with serviceable tyre fitted. £25
