Before I take out the cracked and failing original pedal box I was wondering if anyone had or knew of an available replacement.
Not troubled if its been repaired, reinforced or is just covered in all the mouldy stuff that collects in garage corners I just need to get on
with sorting it out as performance is just embarrassing especially uphill from a standing start
Plus does anyone know whether the 2 allen bolts for the fixing plate are still available from Citroen, I have a feeling a few maybe needed before the jobs completed
I have a good one here, it has been strengthened/repaired but to a good standard, came from my old tgd which was converted to manual, the brake pedal rubber is missing. I have the bolts as well.
£25 plus the post.
Many thanks rutter123 for spending the time and your patience whilst fitting the replacement pedal box on your driveway last Sunday. The drive home was a perfect mix of those wonderful fen roads, B, fast A then the A1 which doesnt really know what sort of road its supposed to be, an excellent way to rediscover just how good this BX really is. Totally transformed the drivability.
An N/A Diesel Auto is a pessimistic place to be when on 1/3 throttle with the pedal buried as a long hill approaches . Seems to have tightened up the brake pedal feel as well, so really pleased. Cheers.
No probs was glad to be of service, and a very tidy bx you have there, glad you enjoyed the hack across the southern fens-roads the bx was built for.
