Hopefully someone on here could shed a little light on a problem that I have.
A couple months back I noticed a clunking/crack from the back end of my bx and it's getting a bit more frequent.
It seems to be when I travel over humpy road and when there's a lot of travel in the rear radius arms.
I've had it up on ramps and can't see or hear anything that seems to be rattling, I've had the brakes apart on both sides to no avail and there is no tinware, exhaust or drop links lose at all.
Does anyone know if it could it be a radius arm baring playing up?
If so what would that sound like?
It sounds like a 'crack' / 'clunk' that's intermittent! If that helps.
If Defender110 looks at this, can you remember if they've been done in the past or if you fitted grease nipples on the radius arms as you owned the white TZD (N89 GJO) once upon a time
Thanks all. Russ
