Battery Light
rugmuncher
- My Cars: BX 1.4 RE, BX TZD TURBO, BX TZD Turbo, BX TXI, BX TZD TURBO
Battery Light
Greetings all. I have a problem with my charging circuit. When the car, TZD Turbo, is switched off the battery light on the dashboard is lit, when I turn on the ignition it goes out and stays out when the engine is running. The alternator does not seem to be charging the battery, I have to charge it overnight from my caravan charger but if I leave the battery connected to the car it doesn't charge. Have I definitely got a duff alternator or could it be a loose wire. All input will be apreciated. ps I hate electrical problems on my bx! Such a pain!
Re: Battery Light
I would say it is definitely a duff alternator gone open circuit.
rugmuncher
Re: Battery Light
New alternator then?
Re: Battery Light
Im breaking a tzd turbo with a good alternator on it £35 inc post. does yours have aircon?
rugmuncher
Re: Battery Light
No, no aircon.
Re: Battery Light
Assume you checked the battery is ok?
1990 BX19 TZS Auto 06/11/1989
Re: Battery Light
I too would go with failed alternator, specifically a failed diode. Battery problems wouldn't cause the light to stay on with the ignition off...
Re: Battery Light
Looks like someone else must've bagged my alternator, sorry
KevR
Re: Battery Light
I had the same problem - turned out to be a worn slip ring on the alternator. As a test, try running the engine and putting a volt meter across the battery. Assuming it's not charging (battery probably at 12-13v), then get suitable long bit of wood, apply to the body of the alternator, and give it a couple of sharp taps with a mallet. This can quite often allow the alternator brushes to dislodge a bit and make contact again, in which case you'll suddenly find you'll have charging voltage (around 14v) at the battery. Drove one of mine around for months like this giving it a tap every few days before I finally got round to replacing it!
New slip rings and bushes are cheap enough, but you will need some soldering skills.
<edit> Note to self - read the original post properly. As has been said above, the fact the red light's on with ignition off probably means it's a diode rather than the slip rings. Still worth hitting it a bit though - might not do anything useful, but you'll feel better....
