Heater tap cable adjustment
frog
x 12
Post by frog »
Hi all,
Have just replaced my heater tap, no leaks now!
When I attached the cable to the new tap I must have put it out of adjustment, eg too much through the securing bolt.
I'm wondering if anyone has a good method for adjusting this with the tap insitu?
This is the tap sans cable out of the car, looks easy enough, loosen the 7mm nut whilst holding the 8mm bolt, adjust cable, tighten.
In the car, maybe not so much, what are your methods?
1989 Citroën BX 16v
1993 Citroën BX 16v project
Re: Heater tap cable adjustment
Post by ken newbold »
These cables must've cost about $100 an inch, they cut them to exact size making them VERY difficult to do anything with! :evil:
Not really an adjustable item, just slide your control lever to either fully open or fully closed and attach whilst the tap is in a corresponding position.
