driver side inner CV tripod joint
Dragon Man
My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991
x 6
Post by Dragon Man »
the chap who took the engine out of my bx has lost all of the needle bearings and one outer race from the tripod joint on the drivers side inner CV joint. sigh.
if anyone has one, please let me know.. i cant seem to find one new for the BX. unless they are found on all XUD engines?
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning 8)
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle :mrgreen:
x 138
Re: driver side inner CV tripod joint
Post by rutter123 »
i have driveshafts for a t/d as well. can send it with the tap? t/d and gti's have fatter driveshafts than the n/a's 16/19's etc tho they are interchangable they are bigger diameter shafts to cope with the extra horses.
Dragon Man
x 6
umm sure.. i only need the gearbox side 3 bearing end bit that sits inside the CV cup. i'll send extra cash to compensate.. heh dont happen to have the rear window washer jet too do you? mine is gone :/
- JohnDragonMan
Why the bloke didn't just remove the shaft baffles me. It's two M7 nuts!
x 138
Post by rutter123 »
No rear window wash jet its gone. /\ as Kitch says 2 11mm nuts is all that hold the intermediate bearing in place i suspect your man has tried to pull the shaft out without undoing these first. i might have an o/s inner joint which has been cut from a shaft it mayhave the bearings and bits you need.
