Power Steering
peterbot
Power Steering
Post by peterbot »
Iv'e found the leak on the TZD. It is coming from the hydraulic ram on the power steering gear. It is weeping, unless you turn the steering to full lock when it sprays out. Now then anyone ever replaced the hydraulic ram? I assume i don't have to replace the whole steering as the ram seems to be held on by just two bolts.
Any advice much appreciated.
Stewart (oily!)
Post by Stewart (oily!) »
Just the two bolts and some pipes, check yellow pages there are places that can overhaul power steering rams.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
