Saloon rear suspension Cylinder
Stinkwheel
Post by Stinkwheel »
Hello forum folks,
Just a quick want in case anyone has a spare, Im after a suspension cylinder to suit the rear of a saloon BX (although I reliably informed an estate one will suffice at a pinch) drop me a PM if you have something suitable. Many Thanks.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 137
Re: Saloon rear suspension Cylinder
Post by rutter123 »
I have a pair of rear struts if you need one, it may need a new gaitor but no leaks. Estate ones will fit but have fatter rams to cope with the extra load, Let me know if you want one £30 plus £5 post.
KevR
Post by KevR »
Yep, estate ones are larger diameter - ok if you want to fit a pair (except finding good estate ones is a lot harder..). Early Xantia ones also fit, but you have to modify the boss where the hydraulic pipe screws in, and fit the operating arm and bellows from the BX cylinder.
I've got a pair of Xantia ones available if anyone needs them.
Stinkwheel
Hello guys, thanks for the responses. Only just got caught up with the thread again i'm afraid. I would like one of your spare ones please rutter123. Only issue I have now is it may have to wait until payday, its been a heavy month with one thing or another. If that's OK with you I will be in touch when the bank balance is healthier :-)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
x 137
Post by rutter123 »
Keep me posted on that Stinkwheel, they are still on the breaker so it gives me time to get them off, which side did you need cant remember if they're sided or same like the fronts, cheers.
KevR
Post by KevR »
They're not sided so no worries there.
Stinkwheel
I will indeed be in touch when ive been paid, as I say, bit tight this month unfortunately. And as Kev rightly says, not handed :)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
