bx bits for sale
x 138
bx bits for sale
Post by rutter123 »
2 x t/d radiators £35 each
2 x t/d dash binacle with surround and switches black £20 each
1 x black glovebox with good hinges £12
3 x front wiper motor all with good spindles £15 each 1 SOLD
1 x pair of estate rear light clusters £20 pair SOLD
2 x Estate n/s/rear light clusters vgc no cracks £10 each
4 x front struts with top plates £20 each 2 SOLD
3 x LHM reservoir with filters £10 each
4 x heater blower control boards £5 each 1 SOLD
3 x t/d head gasket (payen) BR790 1.65mm new in packaging £12 each
2 x pair b-pillar interior light lenses vgc £5 pair
2 x n/s headlamp £10 each 1 SOLD
2 x o/s headlamp £10 each 1 SOLD
2 x o/s front indicator mk2 £5 each 1 SOLD
2 x n/s front indicator mk2 £5 each 1 SOLD
1 x black steering column cover bottom half £5
2 x light switch stalk £10 each
2 x wiper stalk £10 each
1 x radio flip cover fully working black £10 SOLD
1 x pair of lower wishbones brand new unused £40 pair
1 x pair front hubs with bearings £15 each
2 x pedal box (manual) not cracked £10 each
2 x t/d rubber inlet hose (the one at the top just above the engine mount hard rubber) £10 each
1 x timing belt cover set t/d £10
2 x doseur valve £20 each
1 x PAS rack no leaks £30
2 x PAS pipe £20 each
1 x heater blower motor in housing no resistor £10
Front seatbelts £10 each no stalks
1 x o/s/r suspension arm NEW with bearings no stub axle £30
1 X o/s/r suspension arm ABS with reluctor ring and ABS sensor £25
2 x CAV type fuel filter units complete £10 each
1 x black single spoke steering wheel centre cap with badge £5
1 x t/d header tank £8
1 x dash tray
digital clock £5
1 x pair of rear suspension arms suitable for rebuild good condition non abs with hubs 1 has bearings 1 dosen't £40 pair
2 x pair of lower wishbones o/e fitment may need new bushes £20 pair
1 x t/d n/s driveshaft £15
1 x t/d o/s driveshaft with intermediate bearing £15
1 x lower rear engine mount £10
1 x rear wiper motor £10
1 x fuel filler flap blue no key £5
1 x steering column complete £25
1 x ignition switch with key wiring and plugs intact £20
1 x o/s/r door silver no dents £20
1 x n/s/r door silver no dents £20
1 x n/s/f door silver no dents £20
Pair of hatchback bumpers silver ok cond no trims £20 pair
t/d gearbox 5 sp BE3 low miles 80k £40
1 x front subframe no rust £30
2 x diesel hydraulic pumps known good but untested £25 each 1 SOLD
Pair of estate rear speaker grilles in black £5
Central locking controller (under centre console) £10
Doors open display (next to coin tray) black £10
Side indicators repeaters square £5 Pair
Front door speaker grilles black all tabs intact £8 pair
2 x Accelerator pedal arm £5 each
1 x gearstick rubber gator black no splits £5
1 x rear view mirror in vgc no blemishes £5
2 x Fog lamp/electric mirror switch binnacle surround black £5 each
Ashtray black £5
Coin bin black £5
Steering column lower top shroud (with the circular cutout for the steering column) £5
1 x pair rear wheel arch plastic spats will need a paint but in good cond £10 pair
1 x gear linkage pivot (steering rack mounted 2 ball joints from a diesel) £10
1 x set of 3 relays on bracket (bulkhead mounted by rear screenwash res) for a diesel £5
1 x diesel glow timer (blue) £15
1 x blower leaf trap grille £3
1 x pair fog lamp plastic surrounds £5
1 x rear carpet black £10
1 x o/s/f door seal £10
1 x o/s/r door seal £10
1 x n/s/r door seal £10
2 x t/d intercoolers £10 each
1 x t/d airbox complete £10
2 x plastic scuttle panel vgc silver £10 each
Set of 4 window glass with channels from a t/d tinted £20
1 x bonnet stay £5
1 x diesel n/a dash clocks with working clock 105k miles £10
4 x door interior light switches £1 each
I have lots more to sort out yet so will be offering it all up, can post most items smaller bits will be £3 up to max £10 on the bigger/heavier bits UK mainland.
Pluto
My Cars: 1992 BX19TGD ESTATE 178k
2014 Fiat Ducato Sportivo
Re: bx bits for sale
Post by Pluto »
Hi, I'd really like a few of those bits:
1x pedal box
1x wiper motor
1x pair of estate rear light clusters
2x front struts
1x heater blower control board
1x os front indicator
1x ns front indicator
1x radio flip cover
1x os headlight
1x ns headlight
If these are still available please let me know. I could collect if thats too much to post if your able to keep hold of them for a couple weeks?
Thanks
x 138
Post by rutter123 »
Hi Pluto yes got them all, can post no problem.
Pluto
Post by Pluto »
rutter123 wrote:Hi Pluto yes got them all, can post no problem.
Great, I'll pm you to sort out payment and send you my address. Many thanks
anorthfield
Post by anorthfield »
Do you still have the near side front door?
x 138
Post by rutter123 »
yes i got a n/s/f door it's silver no dents or rust, no electric window motor but i do have the glass.
anorthfield
Thanks. Do you know which model it's taken from? I'm thinking of the size of the rubbing strip, which is wider on the TZ cars for example. Ideally I'm looking for a TXS-compatible one. If not, hopefully I can buy a rubbing strip separately.
x 138
Post by rutter123 »
its from a 91 tzd turbo, it has the narrow rubbing strip but they can be easily swapped over as they are only stuck on with double sided tape-the door itself will be exactly the same and will fit. Shouldn't be too hard to find another wide rubbing strip.
anorthfield
thanks for the quick response. It's my son's car, so I'll let him know and get back to you. best wishes.
x 138
Post by rutter123 »
If you decide you want it I will most likely be coming down to Slough in a few weeks if that's any good to you i could bring it with me. It's not something i would want to send by carrier/post.
anorthfield
Thanks. If my son wants it that would be great. I'll be in touch early next week.
x 117
I need front doors for my GTi as mine are rusting so when you know if yours is still available I will buy it.
x 138
Post by rutter123 »
No probs Mr Jaba, it's first come first served as far as im concerned, i got both front doors in good nick tho the driver door has a tiny dent just above the trim strip but no rust on either.
anorthfield
I don't want to hold things up. My son is away, and I'll know tomorrow morning, and I'll let you know immediately. Thanks
anorthfield
Thank you. My son would like the front passenger door. Can we meet you in Slough sometime?
