Oil Pressure Sender (sensor)
- My Cars: Bx 15 TGE
? wanted this sensor
Hello everybody, my bx it need to oil pressure sender can you help me??
D5503 cihaz?mdan Tapatalk kullan?larak gönderildi
Re: Oil Pressure Sender (sensor)
Ebay?
Re: RE: Re: Oil Pressure Sender (sensor)
http://m.ebay.com/itm/New-FAE-Engine-Oi ... Ciid%253A2rutter123 wrote:Ebay?
Price is high 36+48=84$
Which bx is it for? 1.6? 1.9? petrol or diesel?
1.6 petrolrutter123 wrote:Which bx is it for? 1.6? 1.9? petrol or diesel?
My car is bx 15TGE
I'm changed dashboard my car. Water temperature gauge is work good but oil temperature and oil pressure gauge not work. I need sensors for It is work
You need some fuel in the tank tooyarkan35 wrote:I'm changed dashboard my car. Water temperature gauge is work good but oil temperature and oil pressure gauge not work. I need sensors for It is work
IT also works with LPG cars. So the tank is emptyDefender110 wrote:You need some fuel in the tank tooyarkan35 wrote:I'm changed dashboard my car. Water temperature gauge is work good but oil temperature and oil pressure gauge not work. I need sensors for It is work
- MULLEY
Have you got any pictures of your car, we didn't get your model in the uk so would love to see a rather rare Bx
Isn't a BX15 just the euro version of a 16? Seem to recall seeing some 15's in Greece years ago,
MULLEY wrote:Have you got any pictures of your car, we didn't get your model in the uk so would love to see a rather rare Bx
I invite you to our group
https://www.facebook.com/groups/195225230538881/
Hi,
Only just seen this - I'm also fitting GTi gauges. If you want to fit the pressure sender directly to the engine block then you can get an adapter piece like this:
http://www.ebay.co.uk/itm/371117125919
Which will allow you to use a normal oil pressure sender like this:
http://www.ebay.co.uk/itm/351471123148
But it will mean you no longer have the low pressure switch for the red light. If you want to keep that you will need a T piece adapter as well. I'm going to use a remote one like this:
http://www.ebay.co.uk/itm/141434632819? ... EBIDX%3AIT
and an oil switch like this:
http://www.ebay.co.uk/itm/301892700117? ... EBIDX%3AIT
Mostly it's just a case of getting the threads right so sensors match the adaptors - I chose M10x1mm but it would probably have been better to choose 1/8NPT since that is a more common thread size for aftermarket sensors etc.
For oil temperature you either need a GTi sump with the right fitting, or you need to modify your own sump. You can put a sensor in the drain plug hole, but I wouldn't recommend it. - too vulnerable.
