bx17TGD for sale
david troughton
bx17TGD for sale
Post by david troughton »
1991 TGD. White. 122000 miles.MOT til Jan 31 2017. Underneath solid. New rear spheres,oil and filters.
Needs work -
front inner wheel arches need welding.
O/S rear arm bearing needs renewing - it may need a replacement arm?
drivers seat fabric wore through badly (foam still in place).
O/S front window runner rotten so window wedged shut.
N/S back door connection to central locking gone.
front bumper side fixing dodgy.
dings to N/S front wheel arch and rear panel to front of rear wheel arch.
overall tatty but has a lovely engine. with 5 months MOT it is, I guess,what you might call a running project.
I have used this daily since July2012 and it has never let me down.
I just do not have the time, or space, or expertise to sort it out.
£200?
I am now the proud owner of a very nice 1.6meteor but am having trouble with the carb.
Is it still possible to obtain manual choke conversion kits for the Solex wax stat carbs? If so, from where.
Are there any other makes of car that use a sole manual choke that will drop into the bx.
David T
My apologies; the car is situated in Leamington Spa, Warwickshire.
Last edited by david troughton on Fri Sep 02, 2016 2:11 pm, edited 1 time in total.
Re: bx17TGD for sale
Hi David and welcome, a location might help in the sale.
CitroenBaz
Post by CitroenBaz »
hi David solex carbs are ok , they just heed setting up. as keven said a location will help, barry at bourne citroen
david troughton
Sorry, stupid omission! car is in Leamington Spa, Warwickshire
Hi david
The solex carbs work fine when set up well, you need to ensure its all clean and adjusted properly.
