abs front brake hoses
CitroenBaz
Post by CitroenBaz »
HI ALL I NOW HAVE BX ABS FRONT BRAKES IN STOCK<£20 each plus postage, barry at bournecitroen
senmathal
My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
Re: abs front brake hoses
Post by senmathal »
What`s the different between ABS and not ABS?
/Mats
x 138
Post by rutter123 »
ABS are bigger thread fitting on the caliper.
senmathal
Post by senmathal »
Ok! So even the caliper is different. Did not know that. I thought the only different was the ventilated disc and the caliper holder.
/Mats
My Cars: BX GTi, C3 Auto
x 113
senmathal wrote:Ok! So even the caliper is different. Did not know that. I thought the only different was the ventilated disc and the caliper holder.
/Mats
No, the caliper thread size is the same its the other end of the hose that has a larger thread as it has to accommodate 4.5mm piping.
senmathal
Post by senmathal »
I will remember that I have used calipers from other models on my earlier 16 Valve. That explains how that can be possible. Maybe it is an idea to order a pair and put in the sparepart box for the future.
/Mats
Toddman
Post by Toddman »
The ABS hose is this obe -
Brake Hose FRONT Bx 95632790 Delphi LH6015
And yes it has a larger thread at the non caliper end
Please call me Luke :)
http://www.bx16valve.com
