Diesel Bx estate non turbo * towing capability*
Retro
My Cars: Citroen Bx diesel estate 1993
Volvo 164e 1973
Post by Retro »
Anyone know how much I can safely tow with my 1993 flat diesel estate 1.9 ? Safely.....
Thanks in advance !
Retro
Dragon Man
My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991
x 6
Re: Diesel Bx estate non turbo * towing capability*
Post by Dragon Man »
it should be plated somewhere.. i think near the LHM tank theres a plate with the towing weights on it.. i think... it will be in Kg
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning 8)
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle :mrgreen:
JayW
x 13
Post by JayW »
Unbraked: 750kg. Braked: maximum matched kerb weight (around 1100kg).
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 97
Post by rutter123 »
Tho some have towed a lot more, a very lot more....(huh hum)
General rule of thumb is trailer weight (braked) should be approx 85% of the kerb weight of the towing vehicle, so your max on a BX is only 850/900kg, unfortunately with the BX being quite light in itself @ 1000kg ish towing capacity is fairly limited.
Retro
Volvo 164e 1973
Post by Retro »
Thanks for the info
thats not a bad size of lightweight caravan really . A possibility anyway
Thanks for info .
