I'm going to change the coolant on my BX Diesel automatic.
In addition to the radiator drain plug, I understand there is a block drain plug. Whereabouts is this located? A photo or diagram would be greatly appreciated.
BX 19 TGD Auto block drain plug
Dyane425
Re: BX 19 TGD Auto block drain plug
Just draining the coolant from the bottom radiator drain is sufficient, no need to look any further.
Dyane425
Thanks very much.
