wanted
lesg
- My Cars: citroen bx gt
- x 3
wanted
Hi there, does anyone know where I can get a complete front wiper with the wash hose attached as the pipe on my Mk1 Gt has developed a hole in the far end and no longer washes all of the windscreen only the bottom part of it. Would a Mk2 pipe fit and if so are they still around to buy. Many thanks, Les.
really?
Re: wanted
Hi just tried to buy the same part, they are N/A. Didn't try chevronics, Rob Moss is excellent at providing parts if they are available.
I made do again with a renault espace/Renault Master one. They are too long but with the rubber cut down they are a quick fix, especially in this weather. At least I can clean all the screen.
Really's Mum
Really's Mum
lesg
- x 3
Re: wanted
Hi there, thanks for the reply, where do you get the blades from and is it a straight forward job of swapping them over? What size do you order and are they off the internet and if so could I have the web site name please. Many thanks, Les.
Re: wanted
I have a few complete front wiper arms with the spray bar, may need a new blade but they are just standard 21 inch?? i beleive mk1/2 are the same.
lesg
- x 3
Re: wanted
Hi there, would I be able to buy a couple off you as the rubber has gone hard and has split. If I could, could you please let me know the price including the postage to WR14 4HU as I really want to keep the Gt as original as possible as I am hoping to get the odd bodywork done over the winter and am a stickler for originality. Many thanks, Les.
Re: wanted
Hi Les, i have a complete wiper arm here with spray bar and blade if you need it, tho the rubber pipe may need replacing but this should be available from your local motorist shop, the blade may also need replacing as its quite old and gone a bit hard, they are quite simple to replace just the usual standard slide in clip type, so far as i know the spray bar was clear of blockages but a wash through would prob benefit £15 inc post.
lesg
- x 3
Re: wanted
Hi there, thanks for replying, that would be great if you could post me one of the arms to Les Goodrum at the post code on my previous post and let me know how you want paying for the item, my house number is 18. Many thanks, Les.
