Mk1 estate manifold stud nut
Ant4567
My Cars: Citroen bx 16rs mk 1
Land rover series 3
Post by Ant4567 »
Hi i've fitted a new carb to my citroen bx mk1 estate but discovered that one of the nuts on the manifold stud didnt actually fit the stud. Been searching for one for a while but cant seem to find one that fits the manifold stud. I've heard it is a unf nut but not sure if thats the case. Any help would be greatly appreciated
Sent from my SM-J500FN using Tapatalk
Ant4567
Land rover series 3
Re: Mk1 estate manifold stud nut
Post by Ant4567 »
Forgot to add its a 1.6 petrol and a 171c engine the manifold stud keeps the carb bolted down
Is it one of the four carb mounting studs? I'm pretty sure they're M7 on my mk1 16TRS, though whether that's fine or coarse thread I can't remember.
I doubt very much it would be UNF on a Citroen, M7 Metric fine as per Kitch would make more sense.
Ant4567
Land rover series 3
Post by Ant4567 »
Cheers for the responses guys i'll try an m7 and let you know if its right
Ant4567
Land rover series 3
Post by Ant4567 »
For the record it was an m7 appreciate the help everyone
