starter motor needed for k reg 1992 bx tzd 1.7 turbo diesel please
as title please. if anyone has one please get in touch as it now totally gone and not even starting with a tap with a hammer! thanks.
- Jaba
- My Cars: BX GTi, C3 Auto
- x 83
Re: starter motor needed for k reg 1992 bx tzd 1.7 turbo diesel please
Are you 100% sure it is the motor ? Have you connected a jumper lead from battery + to the starter solenoid as this is the best test for a dead motor or a failure in the voltage path from the starter switch/ignition to the solenoid on the starter.
They are available from the usual suppliers still if you need one after testing.
I have several here if u need one all good and working £20 plus shipping @ £8
