G'Day from OZ again!
Is there a replacement for the LHM filler cap available , as mine won't stay in place & makes a mess.
Cheers, Jason
LHM reservoir filler cap?
motorgnome
- My Cars: BX 19 TRI, Mk1 MG Metro, Mk1 Metro VP, Triumph Dolomite Sprint, Lexus LS400
Re: LHM reservoir filler cap?
The caps are usually a loose fit but if you are experiencing a "mess" then it is likely you have a suspension or other component failure and one or more returns have become too vigorous.
Particularly worth locally checking the returns from the struts because if there is a high bypass of fluid on these and their returns blow off or rupture, you will lose most of your LHM in a very short distance.
(I am presuming it is not something simple like that you have overfilled the reservoir and it is overflowing when the car settles after driving?
motorgnome
Thanks for the reply. The BX is my first Citroen & it is an exciting learning curve. I have the whole suspension ,crossmember , brakes out & apart, renewing octopus, rack bushes, drop links, ball joints, lower/inner bushes etc, and cleaning everything. Everything is just so damn oily & filthy, I've spent ages cleaning stuff up. Under the LHM reservoir and along the chairs rail is (was) just thick with filth. So when I see that the reservoir cap doesn't really fit, I assumed that's a problem ..especially when there is a breather pipe from the cap going into the inner wing..
But I will check out the returns.. I really don't like being stranded, so any checks I can do to prevent that are helpful. Besides, LHM is too expensive to waste!
Cheers!
Cheers!
motorgnome
Well, I've "fixed" the loose filler cap, easily enough.
Turning the cap up side down, I pressed a thick o ring, in between the white plastic oil separator & the cap. This spread the cap, allowing a snug fit. Yay
