alloy wheel compatibility
- My Cars: citroen bx 19rd (now sold)
citroen bx 17tgd turbo repairs ongoing. (gone to the scrapyard in the sky)
citroen cx familiale awaiting possible restoration. (rotted away)
citroen bx 14 re. this ones a beauty.
classic mini race spec. - x 2
can anyone tell me, will 15" peugeot 206 alloys go straight on my 1991 bx 17 tgd.
thank you in advance.
andy.
andy.
- Tim Leech
- x 141
Re: alloy wheel compatibility
They should do yes. Just check for clearance, plus as it's a 17TGD it may not have power steering so fitting wider wheels may make it heavy.
thanks. do you know of any thinner alloys that will fit or perhaps i will just get the steelies powder coated or done up.
- Tim Leech
- x 141
Personal choice, 205 Gti's fit straight on and can look good, I prefer the stock look but a nice set of rims can looks much better than rusty steels.
- x 88
206 alloys usually have a bigger offset, so sit inside the arch a bit too much
1990(H) 16Valve (Rouge Furio)
- hilarystone
I would suggest the early C5 'steelies' which are aluminium though look like steels and weigh half the weight of a 16V alloy and have the correct offset.
Hilary Stone
http://www.Hilarystone.com
- x 88
hilarystone wrote:I would suggest the early C5 'steelies' which are aluminium though look like steels and weigh half the weight of a 16V alloy and have the correct offset.
They're aluminium??
- hilarystone
Yes… And weigh under 5kg each…
Hilary Stone
- x 88
What do they look like?
- hilarystone
Here's set on my van:
and a set repainted in white on Ebay here:
http://www.ebay.co.uk/itm/Set-of-5-Citr ... SwDiBZF~~z
They are noticeably thicker than steel wheels and there are two versions – ones which take wheel bolts with flat captive washers and ones which use wheel bolts with a taper. As I understand it the ones for wheel bolts with flat captive washers were prone to cracking…
Hilary Stone
- x 88
I guess the only downside is they still look like steelies! Be good for track cars though.
- hilarystone
Yes but I think that's a positive!
Hilary Stone
- x 88
hilarystone wrote:Yes but I think that's a positive!
Win-win for you then!
