Just wondering if anyone knows where you can get replacements of the above. They go between the gaskets on the carb and fuel pump mine are both broke many thanks Anthony
Sent from my SM-J510FN using Tapatalk
Heat protectors for carb and fuel pump bx16rs mk1
Ant4567
- My Cars: Citroen bx 16rs mk 1
Land rover series 3 - x 2
Re: Heat protectors for carb and fuel pump bx16rs mk1
Hi Any
Mk1 headlamp protectors are pretty much no existent, I have a set on mine which I bought years ago and are after market. They normally fetch more than the headlamps themselves.
The fuel pump is readily available on eBay
Good luck with the 16RS LHD, that car was so nearly scrapped more than once!
https://www.ebay.co.uk/itm/252936027204
- x 94
Tim Leech wrote:Hi Any
He said heat protectors Tim
I never even thought of them as heat protectors, just plastic spacers. I know some fuel pumps run with them, and some without (as there are two different depths of plunger on the pump) and the carbs I always assumed it was because they adjusted in the inlet track length.
Sadly don't have any spare, but wouldn't be too tricky to get some made out of delryn or something.
Ahh lol! What are those!
