BX 1.9 Petrol bottom hose
Guys who did the cambelt said the bottom hose is getting a little tired.
Tryied my usual contacts but no joy!
Any ideas?
x 116
Re: BX 1.9 Petrol bottom hose
If the hose is still intact then what I do sometimes is to use self annealing silicone tape wound around the weak areas for reinforcement and so far have had no failures.........
Hi John
Its the end of the hose where it is starting to degrade,
x 116
Tim Leech wrote:Hi John
You can still use the tape on the end under the hose clip and use silicone sealant afterwards inside to fill the splits/cracks. It will get you out of trouble for a long while until you can source a better hose. I presume the hose is not one with a provision for a smaller hose to connect somewhere along its length.
Hi John
Yes its the one with his another smaller hose feeding off it, and is proving difficult to find.
Kitch did you fit a new one to your Dads?
Sorted, ive crosss referenced the part number on chevronics website of 95610898 and got one sorted.
Nah, his was in pretty good condition, though it's going to be running waterless coolant, so it won't be under any pressure anyway.
x 116
I think I have got one of those hoses somewhere if anyone has the need.......
